RCU Forums - View Single Post - Walbro Diaphrams, Which do you use?
Old 09-12-2007 | 01:45 PM
tim220225's Avatar
tim220225
Default RE: Walbro Diaphrams, Which do you use?
The manual page you speak of shows all possible parts that may be on or in a particular carb. I would look closer at the diagram, you may see that the gasket or diaphragm you see may be for a carb with a primer bulb. Any carb I have worked on that doesn't have a primer bulb only has 2 gaskets and diaphragms.
