RCU Forums - View Single Post - How much does an engine "unload" in the air?
Old 09-12-2007 | 04:20 PM
RTK's Avatar
RTK
Default RE: How much does an engine "unload" in the air?
Pe-- Do not be upset, I don't think anyone is knocking how valuable scientific theory is or what you have said. I will give is simplistic example.
If you gave two people a problem which you needed to solve, one came up with a theory of how it should be solved and the other had already done it many times before. Which persons advice would you be inclined to follow.
