RCU Forums - View Single Post - Basic charging??
Old 09-12-2007 | 06:54 PM
malavivius's Avatar
malavivius
Default RE: Basic charging??
yeah nitro,
the charger charges until peak voltage is reached and then beeps 7-8 times and shows "end" on the screen and stops charging, but also shows how many mA the pack took to fully charge, which is good to compare to the rated mAh. in your case 1400 mAh.
Staying in the same room while a pack charges is a bit hard if you're cycling a pack very slowly as you should when they're new, could take a couple of days if you cycle them 4-5 times. fast charging is where there is more risk of excess heat, but you never know.
oh, and i live at Semaphore.
