RE: Norvel 074 Need Help
Just a speck of grit, or a deformed head shim is enough to cause a problem. Lack of tightness, [depending on your definition of tightness] can be a cause. After an over haul, or whenever the engine seems "off", double check the snugness of everything. Don't go for gorilla tight, just secured.
