RE: Which Engine?
Barry,
The AOA of the blades is one factor in efficiency.
The CL does become greater, so the smaller blades of the 12x6 prop do produce more thrust (compared to a flatter AOA). But their CD, or coefficient of drag increases to a greater extent, causing their L/D (lift/drag) ratio to decline, as AOA is increased.
This is a major factor of prop efficiency and one reason a larger diameter, identical pitch prop, will produce a higher speed at identical RPM.
...But this is really not an issue. The same engine will not be spinning a 12x6 and a 14x6 at the same RPM...
If the model you are flying isn't the sleekest around, using a relatively low pitch prop will provide your model with better performance.
Using a 10x6 prop on your .40-.50 trainer is nearly the worst choice you can make (better only than using a 9x8, or an 8x10 on the same trainer...).
An 11x5, an 11.5x5, or a 12x4 even, if ground clearance permits, will load the engine down a bit, but will provide better take-off performance (shorter run, much better climb-out, never a ground-loop) and better off-throttle breaking, which makes landing easier and shorter.
The cost; a lower top speed, which you have no need for anyway.
So, if the LHS guy tries to sell you 10x6 props with a new trainer, you can tell him that he's a complete idiot...
