RE: I GIVE UP !!
Martin,
Hold on just a second before you do any of that. The frustration that you are experiencing is typical. You have just taken too big a bite of the hobby too soon. You obviously ore not experienced enough in the hobby to expect some of what you have just been handed. This forum is great for asking what does and does not work together. The Spinner normally needs to be cut to fit specific props. The spinner manufacturers will normally cut them for you when you order it (for a nominal fee). The Upscale radio transmitters do require quite a bit of experience to be able to understand what all they will do for you. Lastly, you probably are not advanced enough to try a plane such as you described. Maybe a little more advanced trainer, and a basic computer radio would work better for you. By all means, put the model and the 9C away for a little while, and go with a more reasonable plane and radio system. Or, find someone in your locality who is experienced with this radio, and get them to help you with the setup. Don't break anything out of frustration. The model and the radio won't care, and you won't feel better about it.
Bill, AMA 4720
WACO Brotherhood #1
Bulldog Brotherhood #95
