RE: Where are the calculators???
And it's not only the ESC's that you have to worry about, but the batteries too. You need to keep max amps under the C rating, at least.
Some of the experts suggest, should you want to maximize your battery life, that you run your batteries at 80% of their C rating. So a 10C 2000mAh lipo pack should only be run at 16 amps rather than their rated 20A.
