Servo Voltage
Having a problem with a pair of Futaba s-3003 servos. When I set up the plane I used a 4.8v pack to set centers and such and had no problems. During final setup of the aircraft, I found I needed quite a bit of weight in the nose, so I went to a much larger 6v pack. I prefer to carry battery rather than lead. Problem is when I checked the radio system, I had no aileron control. Have changed recievers, tried changing the way they were plugged in(different channels and such) and one or two other things but the only thing that helps is going back to a 4.8v pack. Can anyone tell me why I'm have this problem? the only thing I have changed about these servos is to install longer leads due to one have a bad lead when I got the plane.
