RCU Forums - View Single Post - Adding An Extra Fuel Tank ?
Old 09-15-2007 | 04:38 PM
drevil
Default RE: Adding An Extra Fuel Tank ?
ORIGINAL: Crash_Course
1.) Is there such a thing as "connectors" to connect two fuel and pressure lines back to one? Like It tried to "draw" below
-------\ \_______
............._______ Ignore the dots.
2.) Would their still be enough pressure to properly pressurize two tanks ?
3.) Would it harm the engine running it for twice as long without stopping it ?
1. What you're looking for is a T connector. There are numerous companies that sell that, but I'm not certain of the fuel line size so you'll have to look that up.
http://www2.towerhobbies.com/cgi-bin...93p?&C=QCG&P=7
2. I think it would run fine, but since I haven't done it I can't say for sure.
3. Nope. It wouldn't be any different than filling the tank up over and over again. As long as it's tuned correctly you shouldn't have a problem.\
Personally I'd go with one larger tank. It shouldn't be all that hard to install and would be much less complicated.
http://www2.towerhobbies.com/cgi-bin/wti0093p?&C=QCA
