RE: Percentage of Nitro in the Fuel
A K&B 21 ducted fan motor won't run on anything less than 25 %. On 15 % you can't get it past half throttle. Very advanced port timing is the reason for it. Mind you this is an exception to the rule. Also, the smaller the motor , the more the improvement with higher nitro. The little Cox motors like the high nitro.
