RE: TT .46 Carb help
Second guessing the next issue will be the factory setting which is now history but doesn't matter anyways.
Open you barrel just a bit to an approximate idle position-this isn't much.
Then close the low end needle.
Next Open the high maybe -2-3 turns
Next attach a fuel line to the carb nipple long enough to blow in
Now Blow into the tube and open the low end until you hear a hissing noise.
This should now be good enough to get you going and dial in from from their
