RE: peak65 vs B60 vs mvvs58
3D-coholic put that 24x8 Mejzlik on your B60 and tell us what it can do. Surely you put enough time on the engine now to have it broken in fully. You will definitely LOVE the increase in thrust with the larger prop, and with all that extra air flowing over your control surfaces
3DDIno remember the pipe moves the CG aft, in case nose weight is an issue.
