RCU Forums - View Single Post - Extreme composite Pro-Line
Old 09-16-2007 | 05:17 PM
  #123
PeterP
Default RE: Extreme composite Pro-Line
Hi Jeff,
No need to laminate if you are using a clevis as the load is the same on either side of the horn. You only have a problem when side loading the horn with either ball links or MK BB fittings. If you want the bling factor then you must laminate
