RE: prop balancing
I spray the back of the light side of the prop with thin coats of clear Lustercote. I let it dry in between each time I attempt to balance the prop so the part that evaporates is gone. This will give you a correct reading. I continue to do this until it's balanced.
Just my method,
Gibbs
