RCU Forums - View Single Post - Engine Mounting?
Old 09-17-2007 | 07:02 AM
DelRay's Avatar
DelRay
Default RE: Engine Mounting?
If you have a small or 6" dial slide caliper you can reference all the mounting holes off the back side of the mount, or reference the back two mounting holes in this manner and then use the motor to locate the forward two holes. This will ensure the motor is square on the mount, any side thrust must come from the firewall then if it isn't square to the centerline of the plane.
