RE: Servo Voltage
Don't know what they did b4 changing leads. One was new, the other was used but had a bad lead anyway. I know they should work on 6v if they work on 4.8v, but they don't. All they do is twitch when I turn on the power and don't respond after that. Put the 4-cell pack back in and everything works normally. Yes I've changed recievers and done everything else I can think of. Each servo is even plugged into different channels(1 and 6). I may just change both servos to avoid having an inflight failure. Just means that the plane won't fly till next season.
