TX Mods for CX-2 What a difference ! !
I smoothed the grooves on the throttle ring, removed the rudder spring, softened the right stick springs.
I can now fly so precise, that I can pick up little spiderman character with grapple hooks (from a Radio Shack Bladerunner purchase) like a pro ! ! My landings are like a butterfly with sore feet !
This is coupled with moving the ball linkages out 1 servo hole as well (to the second hole) for added sensitivity, smaller dead spot.
I can keep the chopper about 1 inch off the floor within a 8 inch radius for long periods of time with the tiniest inputs with the stick!
Except when our A/C turns on.
Newbies; stick to the factory settings until You don't brain fart too much before doing these mods. because of the added sensitivity, but ultimately, I really believe that it will make You fly much better when You don't have a ratchet hole and springs to deal with.
Gary
