Time for a new installment. The following list is not necessarily a true speed secret, but basically a list of materials needed for a newcomer or seasoned pro that was interested in building a Quickie 500. I tried to group materials by supplier, and tried to use as few suppliers as possible. Other than KlassKote, I am not affilliated with any of these suppliers. If anyone has other recommendations or cheaper options, please let me know. I'm still trying to decide on what fuel line to recommend, or to a good source for fiberglass (I bought a 25 yard roll of each years ago, and haven't had to buy any in ages).
Quickie 500 Parts List
Bolts:
Firewall: 4 Each Socket Head Cap Screw - Alloy Steel ¾” long 6/32
Available at:
http://www.microfasteners.com/catalo...cts/SSCSCA.cfm
Landing Gear: 3 Each Flat Head Socket Screw - Alloy Steel ¼” long 6/32
Available at:
http://www.microfasteners.com/catalo...cts/SSCSFA.cfm
Wing Hold Down: 2 Each Flat Head Machine Screws – Nylon 1 ¼” long ¼-20
Available at:
http://www.microfasteners.com/catalo...cts/NYLNBF.cfm
Wing Hold Down: 2 Each Flat Head Machine Screws – Nylon 1” long 10-24
Available at:
Glues / Brushes:
Thin CA 2 oz
Available at:
http://www2.towerhobbies.com/cgi-bin...&I=LXPT38&P=ML
Medium CA 2 oz
Available at:
http://www2.towerhobbies.com/cgi-bin...&I=LXPT39&P=ML
CA Kicker 2oz
Available at:
http://www2.towerhobbies.com/cgi-bin...?&I=LXMYL9&P=7
Z-poxy Finishing Resin
Available at:
http://www2.towerhobbies.com/cgi-bin...&I=LXCX58&P=ML
Elmer’s Ultimate Polyurethane Glue 4 oz
Available at:
http://www2.towerhobbies.com/cgi-bin...?&I=LXLZK2&P=7
Epoxy Brushes 3/8” 12 each
Available at:
http://www2.towerhobbies.com/cgi-bin...?&I=LXBH59&P=7
Hardware:
Hayes Clevis – Black nylon with steel pin for Ailerons (2 per plane)
Available at:
http://www2.towerhobbies.com/cgi-bin...&I=LXK847&P=ML
2/56 pushrod – Ailerons and Elevator pushrods w/threaded ends (1 pack is good for 2 planes)
Available at:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFV05&P=7
4/40 pushrod – V-Tail Torque Rods
Available at:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFV02&P=7
Dubro Blind Nuts 6/32 – 7 needed per plane (This pack is good for 3 planes)
Available at:
http://www2.towerhobbies.com/cgi-bin...?&I=LXE116&P=7
Throttle Pushrod Cable (1 pack is good for 2 planes)
Available at:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFU95&P=7
E/Z Connector for Throttle Pushrod Cable (1 Pack is good for 2 planes)
Available at:
http://www2.towerhobbies.com/cgi-bin...?&I=LXD927&P=7
Ball Connectors – 2 for Elevators, 1 for Throttle
Available at:
http://www2.towerhobbies.com/cgi-bin...?&I=LXK094&P=7
Ball Links – 2 needed for Elevator V-tail linkages
Available at:
http://www2.towerhobbies.com/cgi-bin...?&I=LXD896&P=7
Latex Foam for Battery, Receiver, and tank (1 sheet good for a couple planes)
Available at:
http://www2.towerhobbies.com/cgi-bin...?&I=LXL430&P=7
Velcro to hold Battery / Receiver in place
Available at:
http://www2.towerhobbies.com/cgi-bin...?&I=LXK203&P=7
Landing Gear – Great Planes Dural Landing Gear .019 L-1
Available at:
http://www2.towerhobbies.com/cgi-bin...?&I=LXJ921&P=7
Wheels with Axles 2 per plane
Available at:
http://www.pspec.com/details.asp?ProdID=39&category=7
Fuel Tank – 5 ¼ oz Tetra
Available at:
http://www.pspec.com/details.asp?ProdID=41&category=7
Carbon Fiber Pushrods 35” long 1/8” diameter with titanium ends (I set is good for 2 planes)
Available at:
http://www.centralhobbies.com/contro...e/pushrod2.htm
Fiberglass - ¾ oz and 1.4 oz
Available at:
Fuel Line – ? Still deciding.
Paint – KlassKote
Available at:
http://www.klasskote.com
Radio Gear (Brand is Builders preference):
3-Mini Servos (Elevators, Ailerons)
1-Micro Servo (Throttle)
1-6” Servo Extension (for Ailerons)
1-Mini Receiver
1-720 MAH NIMH Battery Pack
