RCU Forums - View Single Post - Great Planes RV4 40 flutter
Old 09-18-2007 | 11:38 AM
RCVFR
My Feedback: (7)
Default RE: Great Planes RV4 40 flutter
When you get it all put back together, you might consider dropping some prop pitch. I don't know what you have been using, but it (apparently) is a bit too much pitch resulting in a bit too much speed, resulting in............ you get the idea! I like the Mag 46 and I have used it with 11X5, 11X6 props, and on a Pulse XT, a 12X4 with good results. The Pulse is a low drag airframe, and even with the 4" pitch prop, it is surprisingly fast.
Good luck with your rebuild.
