LVC is low voltage cutoff. When some speed controls see low voltage on the battery they pulse the motor to warn you to land. If that is what is causing it you should to throttle right off for a few seconds than throttle up again. It should run ok again for a few seconds till battery again reaches lvc and starts pulsing again. You should get the same problem if you run it on the ground at full throttle for a minute or two.
ORIGINAL: codimasta
LVC ???? When the model is in the air...I get a wooooo....wooooo....wooooo sound. If I hold on to the model and throttle up
it sounds normal... woooooooooooooooooo it is hard to explain..I hope this makes sense,
Codimasta
