You got me. Check your prop is not to big or weak. I have a E-Flite 450 and had never had that problem. Other than being sure the motor is not over proped I am out of ideas.
ORIGINAL: codimasta
[8D] I wish it was that simple....this just happen after about 6 flights...2 flights per day....
I am using Thunder Power 2100 ma @ 11.1 v...the batteries are fully charged 12.6v....changing packs did not correct the problem.....here is something really crazy...the pulsing stops just for a second while I roll it or loop it ????
I think its the motor ???? Cut off voltage is set at 9V
Codimasta[
