RCU Forums - View Single Post - OS .46 AX Velocity Stack
Old 09-19-2007 | 12:35 AM
DarZeelon's Avatar
DarZeelon
Default RE: OS .46 AX Velocity Stack
Geek,
As Julian hinted, the only advantages your piece of work will bring to you, is less wasted fuel (and a cleaner plane).
Even this is true only if you use an unusually large prop that would 'promote' spit-back (the term 'stand-off' is not right here...).
And it is beautiful, but could be bothersome (in a gashing way...[:@] ), if you flip-start your engine...
