RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 09-19-2007 | 08:16 PM
  #4342
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
Mrasmm (Got it right again),
My pinion puller did come with the bar that has the 2 V's. It's very versible, lots of options and configurations.
Gyro mounting: See picture, manufactures sticker is facing the right side of the heli. I've tried it both, left and right side. Reason I went with the right side.. Look at the wiring and sevo plug, facing to the rear. Easy access, if mounted the other way. It's impossible to remove the plugs without removing the gyro.. Mount the gyro with double sided sticky foam tape. You want to eliminate as much vibration from the heli to the gyro as possible. The thicker the foam the better.
Later Rex, need anything PM me, I don't have the time to check the thread as much as I use to.
Dave / Choppersrule
ORIGINAL: mrasmm
hehe yeah man, you gota get flyin =)
Good to hear from you as well. I haven't seen you around alot lately, glad to hear things are going well for you though. I like the bar peice that you have with the two V's in it. My puller doesn't have that and if the pinion is too close then I have to pry it a bit with a screw driver first. Did that come with it?
yeah, that setup should be alot of fun. How did you mount your gyro? With the white sticker to the side with the text right side up? I've seen it mounted so the white sticker faces the back. Would that be correct also, or what's the best way to stick it?
Thanks for the help =) I like it around ehre if someone doesn't know something or just knows a bit, people keep adding their bits of info until we've got it figured out =) Like back in the day the DD setup =)
