RE: Anhedral stab setup
You could use a single hardwood pushrod, wrapping and expoying 2 metal pushrods to it,and exit the fuse at the same distance from the tail to a set of bases with adjustable control-arm posts. ( Making sure the main pushrod goes down the center of the fuse).
Mont 2 servos ( one on each side) for eack stab half.
