ORIGINAL: cltmte
noguy -
yes I pretty sure that is the belt drive you describe. I have the MH main gear installed and the drive for the belt mounts to the underside of that and I believe the tail is a plastic t-rex tail. The HBKII really sounds like deal and from everything I have read, it seems to hold tight in the tail, but there is no parts supprt with my LHS either OEM or knock offs so that is why I went with the belt from freestyle. I should be able to get most replacement parts within a day. I will let you know once I get it and have installed it.
mrasmm -
I went with the e-flite park 370 brushless main
Your looking at the belt drive mod1 then I believe. It is a bit more spendy but have you seen the mod 2 kit? It really cool, has a belt driving pinion gear and then the belt drives the main gear and the tail.
This pdf has grat pics. [link=http://www.freestyle-hobby.com/catalog/images/Belt%20drive%20inst2.pdf]Freestyle hobby belt mod2[/link]
