RCU Forums - View Single Post - Different wing types
Old 09-20-2007 | 08:43 AM
da Rock
Default RE: Different wing types
ORIGINAL: Flying freak
one question what do you mean by "And do the diamond one to the same thickness you do the symmetrical, with the max thickness located the same chord station"
do you simply mean to make all 3 wings the same thikness at the same point (distance from the LE)?>?
thanx for all the help
Steven
You betcha........
To do a somewhat meaningful comparison between things, the things have to have something in common. In aerodynamics, you'd want the wings to have the same area and the airfoils to be the same thickness. THEN change stuff to compare.
