RE: Help with PPG paints!
Yep. Omni is an enamel, use reducer to take it off. If the original paint has been on a while, the reducer will not even touch it. May take your primer off though.
You should be able to remove it all without any damage to the underlying original paint.
Just have to reprime and prep it again.
I work with PPG all day long.....I run a collision center.
