RCU Forums - View Single Post - tail blade dia. does it make a differance?
Old 09-20-2007 | 03:13 PM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: tail blade dia. does it make a differance?
The stock raptors will run 92, the titans will run 95 w/o hitting anything though I'd run 92 even on the titan for ground clearance.
Good carbon blades are stiffer than stock blades in addition to the larger rotor disk so they do perform better.
