RE: 3 channel radio questions (3pm?)
the third channel is offten used for reverse in cars and trucks, I dont know if there is a variable one or not, you would almost need it if you are going to use it to adjust the mixture while running, is that the planned use??? you could also set it so that the travel is short so you could flip it and lean it out a little, but that seems pretty limited...hmmm
