RCU Forums - View Single Post - McCoy 35/40 question
Old 09-21-2007 | 01:54 AM
downunder's Avatar
downunder
Default RE: McCoy 35/40 question
Yep, that's wrong. The baffle has to be on the transfer side but seeing that's wrong then I'd check to make sure the liner is in the right way too (top of exhaust port is higher than the transfer port). Also check that the rod is the right way round when you turn the piston 180 so that the small chamfer on one end of the bush is facing towards the crankweb.
