Moki 360 Twin
Hi folks out there. I need some help to locate some replacement parts for my Moki 360 which broke the crank pin while I was running it in.
No its not covered under warranty as it is an "old" but new motor.
Parts required are front crank with the 10mm crank pin, front con rod, front crankcase (relieved for the bigger bottom end con rod) and the intermediate disc.
Any suggestions and help on this would be much appreciated.
rjmods
