RCU Forums - View Single Post - Powermax Trigger Valve -- New Source
Old 09-21-2007 | 08:28 AM
  #34
lov2flyrc's Avatar
lov2flyrc
My Feedback: (24)
Default RE: Powermax Trigger Valve -- New Source
Jon,
When using the onboard start tanks it is suggested to use powermax over propane. Propane has a higher pressure ratio than the powermax propane/butane mix. Because of the higher pressure associated with propane, in high ambient conditions, your festo feed lines can burst. This is really the only reason powermax is suggested over propane....
