RE: CoroCub - a little bigger one.
Fuselage
One piece 4mm coro made like original plans showed. The only difference in the design is the wing mounting. I will use 4 nylon screws mounting each wing half from the top instead of front mount dowels. Pieces of plywood and spruce were used to create positive connection between the wing mounts, landing gear block and the engine mount. Pictures below
