Here's your answer, and not such a dumb question.
Why are Butane and Propane used in combination?
While butane and propane are different chemical compounds, their properties are similar enough to be useful in mixtures. Butane and Propane are both saturated hydrocarbons. They do not react with other. Butane is less volatile and boils at 0.6 deg C. Propane is more volatile and boils at - 42 deg C. Both products are liquids at atmospheric pressure when cooled to temperatures lower than their boiling points. Vaporization is rapid at temperatures above the boiling points. The calorific (heat) values of both are almost equal. Both are thus mixed together to attain the vapor pressure that is required by the end user and depending on the ambient conditions. If the ambient temperature is very low propane is preferred to achieve higher vapor pressure at the given temperature.
