RE: WACO YMF
Thanks Stickbuilder.
That clears it up. I also thought by one piece you meant one piece entire wing both top and bottom all one, I was going to go all the way around in one piece. Glad you cleared that up as well.
No shrinking can be done until the wing is completely covered, top and bottom? That sounds like a no brainer but I've been wrong a few times here. By shrinking the bottom without the top covered would cause a twist or warp in the structure, right?
Sean
