RCU Forums - View Single Post - FP-T7UAF and FP-R127DF compatible?
Old 09-22-2007 | 06:53 AM
aerowoof
Default RE: FP-T7UAF and FP-R127DF compatible?
they are compatable but the tx must be in ppm mode not pcm mode.this model transmitter can transmit in both modes depending on how you program it.check the manual on how to change modes or to see which mode is being used.It has been awile since I've used a 7 u but on the lcd it should show either ppm or pcm in small letters near the top somewhere.
