RCU Forums - View Single Post - Glow Plug Eater!!
Old 09-22-2007 | 07:06 AM
Nathan King's Avatar
Nathan King
Default RE: Glow Plug Eater!!
I will disassemble the engine and check the bearings/sleeve.
navav2002, I set the pipe is set fairly conservatively, so the needle setting is pretty broad and not "peaky".
airbusdrvr, I have used the "F" plugs.
I am pretty obsessive about checking the mixture and am almost certain that the engine is not running lean. The plug is not giving the usual evidence of a lean run.
I hope to give an update later today.
