RCU Forums - View Single Post - semi semitrical wing chariteristics
Old 09-22-2007 | 10:37 AM
combatpigg's Avatar
combatpigg
Default RE: semi semitrical wing chariteristics
Good point Ray, make sure that the CG didn't shift from the original spot. Also, now that you have changed the airfoil and laid it down on the Q-Tees' hardwood wing mounts, the angle of attack of the wing is different now? I imagine it sits with the leading edge up high? You would need to shim the trailing edge of the wing up to compensate, I think.
