RE: gms motor
Did you adjust the low end idle mixture? When you say it won't idle, how long is it before it dies? I don't think glow engines will run forever at idle, but you should be able to get 30-45 seconds out of it before it loads up.. I'd try leaning the low end needle 1/8 of a turn and see if that helps at all.. Probably too rich..
