RCU Forums - View Single Post - semi semitrical wing chariteristics
Old 09-22-2007 | 07:47 PM
hogflyer's Avatar
hogflyer
Default RE: semi semitrical wing chariteristics
You said you kept the center cabane and rib profile as stock. When you built the semi-symmetrical section and cabanes, did you keep the wing incidence at the center section the same as the stock wing, or did you re-adjust the angle of incidence of the wing to accommodate the new airfoil?
Hogflyer
