RE: Glow Plug Eater!!
Will, you're not kidding about those nickel plated sleeves. This one if from an early (30mm bearing) SF .61. This particular engine is getting a ringed piston/liner replacement with a new ring and new bearings. That should give it new life.
Nathan, does your sleeve look anything like this?
David
