RE: Rotostart not turning the engine over
vnmsqt,
can you put the one way bearing in several different ways? when i take off the backplate, i see a large hex nut shaped piece that the backplate fits over that turns the flywheel (i'm assuming that's the owb)...if i take that piece out, it has a shaft that fits in the hole into the engine...i can't take anything else out unless i use a hex wrench, so there's really only one way to put that thing in...i can't put it in backwards, isn't that correct?
