RCU Forums - View Single Post - How do I reset the Battery on Parkzone Spitfire?
Old 09-23-2007 | 05:12 AM
GeorgeC525
Default How do I reset the Battery on Parkzone Spitfire?
Now everything is fine and working on my new Parkzone spitfire, I read through the "Boot up" page which lets you select a battery, I accidentally went into this mode when playing with the throttle, and now it is beeping 7 times, indicating "70% Soft cutoff"
A different number of beeps tells the engine what battery it is using (If you decide to change the battery) It came preset to a 9 Cell 10.8V Ni-MH battery.
How do I change back to the default setting, as I do not want to risk breaking anything by the plane thinking it is using a different battery.
Ok, to sum up, I accidentally changed the planes settings so it thinks it is using a different battery, and I want to change it back to default, how do I do this?
