ORIGINAL: tewitt1949
The incidence really didn't change from the flat wing.
But, it did!
Compare these two views of the same semi-symmetrical airfoil (2414):
The top view shows how the ribs sit on the building board when constructing the wing (in this case a Sure Shark).
The bottom view shows the actual incidence of the airfoil/wing when attached to the fuselage.
Look at the difference in the angles of the dashed lines.
David
