RCU Forums - View Single Post - semi semitrical wing chariteristics
Old 09-23-2007 | 03:33 PM
hkbii
Default RE: semi semitrical wing chariteristics
Howdie gents. I would start by adding shimes under the t.e . the datum line should run throu the center of the rib, to do this the t,e will have to be raised. set the wing so that the center of the leading eage and the center of the t,e are at o to 1/2 deg pos. this should give a good starting point. hkbii.
