RCU Forums - View Single Post - ABS cowl in kit
Old 09-23-2007 | 06:10 PM
mteal
Default RE: ABS cowl in kit
I just put this same cowl together. The only thing that I had to do different than the other posts is use an epoxy filler instead of bondo. I tried the bondo first and that ended up cracking out on me. I used some stuff that is for repairing plastic automotive bumpers. It is flexible and will not crack out on you.
Mteal
