Autopilot
Hi,
I am glad to hear that it worked fine in a single rotor autogyro because that is what I have. I am quite new to autogyros so maybe I should first find out the characteristics in a fixed wing plane.
Did you have any problem with the elevator channel of the autopilot? An autogyro flies with a large positive angle of attack compared with a fixed wing plane. At least the one I have. Did you take that into consideration when you installed the sensor?
/PO
