RCU Forums - View Single Post - Spray Guns
Thread: Spray Guns
Old 03-22-2003 | 04:02 AM
DavidR
Default Spray Guns
Kevin,
You need to make up your mind which you are going to paint more of..... if it's models you need the smaller gun. The Walcom with the 1.2 mm tip is ideal for this. DO a search (or call me) and I will tell you all the different tips, and accessories I have for mine that make it the ideal gun for model painting. If you are going to be spraying more cars then you need a 1.6 or larger tip, and a larger gun. I use an older but still good, suction feed spray gun for some of the panels, and racks that we have to build and paint for my customers.
DR
BTW the Walcom comes with the fancy smancy case.
