ORIGINAL: B1Driver
Ron, Im going to go with Intarico wheels and brakes along with Robart straight struts (1/2in). I'm thinking of 66mm (2 5/8 inch) Mains Set and a 57mm Nose Wheel. Should I go with the 76mm ( 3 inch) mains and the 66mm Nose Wheel. Im choosing this route because its the most common to find spare parts amonst friends when your in a bind. Which Robart 1/2 strut do you think works best? I'm just trying to gather the info for the best performance and not have to tinker with this at the field..especially the gear. Thanks again for your inputs guys, keep them coming.
P.S.
I've recently heard that these airframes like to do a violent snap in tight turns..believed to be caused by the horizontal stab being so close to the main body of the airframe. Any of you have this happen and or have a solution.
Luis
Check post #2 ans 3 above...........................................
