RCU Forums - View Single Post - Strokes
Thread: Strokes
Old 09-24-2007 | 12:12 PM
opjose's Avatar
opjose
Default RE: Strokes
ORIGINAL: Electrolight
Whats the difference between 4 stroke engines and 2 stroke engines? The price jumps almost 200% even when they both are rated a .70 engine.
Electrolight
I assume that you already know the difference between 2 and 4 in terms of basic functions...
e.g. Like 2 cycle versus 4 cycle engines
A 4 stroke engine has a nicer sound and you'll hear everyone say "it can turn a bigger prop".
That is somewhat true...
However compare the output power of a .70 2 stroke engine verus a .70 4 stroker and you'll find that the 2 stroker engine is far more powerful.
The reason for this is that the 2 stroke engine ignites the fuel on every movement ( compression ) stroke of the cylinder. The 4 stroker, does it every other time.
As a result the 2 strokers build higher RPM's, but they feature ligher cylinders and less moving mass.
Conversely the 4 stroker uses a larger cylinder with more mass to help carry the engine through the non firing cycle.
The 4 stroker then tends to burn less fuel too. They also sound much nicer, more like a real plane engine.
So let's say you are looking at a .60 sized plane, and the instructions call for at most a .60 sized 2 stroke engine.
You could put in a .60 to .70 2 stroker or to get the equivalent output you'll need about a .91 ( yes this is inexact ) four stroker.
The four stroke engines cost more because they are more complex.
I've had about equally good luck with 2C and 4C engines.
Usually 2 stroke engines are used on "smaller" planes. As you move up fuel consumption rises quickly on the 2 strokers, making the 4 strokers a bit cheaper in the long run.
I typically go to 4 stroke engines in planes around the .90 and above size ( with a few exceptions ), and use 2 stroke engines on planes smaller than that...
Between .70 and .90 it's a real toss up for me.
